i see all. i am Morpheus
You know the best things in life arent for me
You know the best things in life, arent for free
Everyone of you could be the same
Everyone of you could play the game
Got a new life, got a new plight yeah
And its going nowhere
-D
question do i have the most boganist family
i have aunty her and her partner both have special edition peter brock vl's that are pride n joy. they named their kid BROCK (destined for a good life kid)
another aunty has a her house so full of crap she blocked off 1 of her hallways to store more, you have to walk around the long way to get to bedrooms
this is what happens to you when you grow up smoking too much weed kidz :) enjoy that happy tree kidz it will be ur demise
Edited by Inline 6
not taking any sides here, but in a car you can turn the steering wheel 45 degrees in a split second just before impact......you try that on a bike and you go high side over the handle bars with every chance of spearing the ground head first :)
only if you gota ride on bus like sled, heard it was the commo of the bikerboys world ;) burnnnnnnnnzzzzzzzzzzddddddddddddd
in irrelevant newz, my brother after a failed attempt at importing a car has instead decided to import a jspec yuki.
No thats not a japense bike apparently he's picked up
and vu stop worshiping your false vtec god, variable valve timing might improve fuel economy but my care factor is low when flying past your ass in my 1.6L pulsar monster
Edited by Inline 6
Awesome. i hear Japanese girls make the best wives. Whats her FOB price?
ewwww.............
side effects of being pregnant hey? :cool::)
Icing sugar on popcorn is awesome!
Just changing subject a little here.... Did you end up getting those quotes on the Motul oils?
Sorry if I've missed it earlier in this thread :)
Does not come with warranty, no English manual, not sure if she go’s hard – will not be testing either. May complain about the heat often but you wont understand the Japanese so best to ignore that problem.
$2,000 plane ticket uncomplied
Appears to be free from defects, will not need to go through regency but customs may require a check.
vin diesel quote
for those that respect fine body work no matter what the make
alternate fnf qoute
why dont you get a nice japanese girl like the rest of teh gaijins around here
hey if you marry someone they get half your assets right but does that work for liabilities as well? Cause they guy has nothing but a huge debt n no assets, maybe he could palm half off :)
and tablo how you change the topic of wasteland its random dribble
Edited by Inline 6
So far Repco came back $230 cheaper then autobarn on gear 300. Cant remember the other prices, got them written down somewhere. Gonna see if i can get them cheaper else where.
No worries. I'm not desperate for the gear oil yet but I want to do an oil (engine) change pretty soon and am still debating whether it's worth spending the extra on 300V over 8100 xcess.
I'm bored shitless at work and have plenty I can be doing at home :)
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
