do it. only have 3 spaces left.
those little bread dinner rolls u buy from the supermarket frozen
chuck those buggers in the oven n toast em and chuck in some shaved chicken and jarlsberg
pimpin.
rick james never had it as good as me - this post is 4 ruby haha
-D
may need one on the way home if my gearbox goes bang.
Your gearbox wont go bang, my gearbox crunched 3rd from the day i brought it. I worked out i just needed to shift slower. 4 years later and its still working fine :P
^^you mean from 1st to 2nd? it's normal when cold... i think double clutching is a way to get around it
Yeah from 1st to 2nd, especially at higher revs. but also going into 1st like at traffic lights etc. But it seems to have stopped crunching/grinding all together now so Im happy with that :P
Dropped the mrs of at work this morning and for some reason the car felt like it had heaps more poke than normal.... I don't know if it's just me but the car seems to behave differently (response wise) on different days lately....hmm!
Well Im off to buy some oil and a filter today for the 32. Searched SAU on what oil would be good for a RB20DET, that just confused me more lol. The car has 158k on it but its been extremely well looked after. As far as I can tell, Motul Turbolight 4100 would be good for it.
If anyone has any suggestions, that would be greatly appreciated, otherwise I'll just get that.
I spoke with some lads some time ago about the Motul oils. The 4100 is good for 10,000kms but who's going to leave the same oil in their car for 10,000kms? 8100 is half the price and is changed twice as often (every 5,000kms). The end result was: with the 8100 the two oil changes every 10,000kms (5.000kms each) mean you'll have fresher oil more often.
So I stick with the 8100 every 5,000kms. Same cost in the end.
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
