Should've read "stuck on 16psi" not "stuck with 16psi" ... not like you had a choice by the sounds of it.
Obviously you ran it on AWD. I'll be squeezing my lemon later in the year to see what I can get out of it ... in AWD also (and a manual box conversion).
I recall Ben (Grim) passing comment to run 24psi in this stag eventually. Be interesting what he gets out of that "family wagon".
Yeah, stuck on. No choice, still happy but
@Ryan, yes, yes you do :)
Guys, my car is still up for sale...It needs a good owner...It's sitting in the workshop all lonely. :)
$18990 Might wack it up on Carsales soon.
I NEED a GTR.
im so tempted by that. its almost retarded.
So whos gonna join me in the 400kw+ club next year? I cant be the only one.
Is this 400kw+ in drinking booze?
No one can compete with you there Luke :) You the champ.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
