lol. figured with the amount of genuine shit id thrown at it recently, id continue the trend. :D
not a bad price, was 30 odd beans for 3 litres of concentrate, and 10 bucks for 10 litres of demineralised water, so yeah, works out the same price as *insert name* coolant, just has a nissan badge on it. :D
im off overseas for a month in about 2 hours, is there anyone who thinks there up to my level of annoyingness to carry on my duties for said period?
duties entail:
- laughing at ruby.... alot.
- gettin talbo upset (easy task, altho he tends to try ignore. a pro knows ways around this)
- pushing luck with mods
if you achieve greater than a 20% warning during my time away then you can apply for a full time position.
kthxbaiiiiiiiii
ohhh P.S
in regard to payment, you go into the draw to win the internet. for proof of how awsome this prize is please refer to attached picture:
^^could be you
Edited by rhys5169
Ok, just had a weird thing happen with the 33.
Hasn't been driven for over a week, so i take it for a quick spin around the block. Get home and can smell burning rubber, popped the bonnet and the power steering belt has decided to walk off the pulley by one rib, but only on the pump pulley?
Belt is not over loose (possibly a little loose, no adjustment left, time for new shorter belt!)
Going to check harmonic balancer bolt, just to be on the safe side.
duties entail:
haha, you certainly do all the above well.........have a good trip where ever that may be
You already push your luck with me Dave so you're definately a shoe-in
be more of a shoe in when you put your foot in his ass to kick him outa here :)
sorry havnt posted today needed to get my fix of daily dave abuse :P
back to study
Edited by Inline 6
Hey Mitch, fork out $1200 for a lawyer like what I did. Then fork out $400 in court fee's and then another $300 in fines.
Even then, there's no guarantee you'll get off the fine.
if i had that kind of cash id be using it to get my car working man :)
That is weird. I'd take the option of a newer (correct size) belt.
Yeah just checked crank center bolt and thats tight. Belt was a 3pk855, reckon i'll go the 845. Just a bastard of a job getting to the tensioner nut though!
Well, I got to check out the 33 up on a hoist today and its very respectable underneath.
Got the Stagea booked into MV Automatics to have the solenoids replaced ... $630 :P
Also lined up a GTR box for the Stagea for the manual conversion later this year. Time to shop for the other bits :)
Try doing it in an RB S13 :) There is literally like 2cm between the harmonic balancer and the rad in my car (doesn't help that i have a fking huge rad in it :P)
Edited by AndrewJZX100
so, this was an interesting day
get my rego renewal for the patrol. tells me to ring them up as there's problems
ring them up
"oh, your car is defected"
"no its not"
"yes it is, 17th march it got done"
"riiiight........i got that cleared"
rang sturt. they punched it into the system and voila..........im still flagged as defected. Said i came in and got it cleared a few days after, but ive since (read: a month ago) ripped up the slip as i thought id never need it again. They just rang me (mid me typing this post) to tell me in the last 3 and a bit hours of checking the till receipts, they found my receipt and have put the defect thru as cleared in the system (finally)
what a lol
Lucky then that taking the radiator out is a 5 minute job :)
What did you get defected for Matty?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
