How much is safe? I might have to do some homework on ebc's... :P
12 psi if youve got a ceramic rear wheels. 15 or so if youve got a steel rear wheel.
seeing as im not using the turbotech at the moment, youre welcome to give it a crack if you want?
I'll let you know, I might have to re-think it all (which is difficult today after last night's b'day celebrations). If you want to get rid of sooner rather than later though I'll still buy it but I might wait until I get a half decent gauge before doing anything with it.... long story short, I'm in no real hurry. :P
Its has a vent in the front of it Chad which u attach a cold air intake. Im pretty sure with the bonnet closed it would act as a seal and just use the CAI to get air.
I though about getting one years ago but decided it wasn't worth the money. Very happy with the set up i have now :)
lay it in there, do it in a well ventilated spot. leave it for about 10 mins, you'll hear it start cracking the deadening. should be as easy as going thru afta with a hammer and chisel and breaking it off
oh, and due to the fact it freezes thru the metal, dont start / drive the car for at least 24hrs........may have snap frozen fuel lines and the like. its fine after that time
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
