I can highly recommend jack for solder jockey work ;D (after all Im shit at it and made him do it all)
My dick is still bigger than his tho yall
-D
Bahahaha :laugh:
If any one wants to check out VDO's range of gagues...
http://www.egauges.com/vd2_main.asp
i might be getting Saber gauges depending on the price :laugh:
i recall have a chat to you about saber, i believe i may have included the following words and terms;
cheap
crap
avoid at all costs
also, lol at the post stats for the wasteland.
Damo_R34 2354
Madaz 1914
and a quick question, if i go ahead and say, buy a 2871R, id pretty have to get a retune eh...?
Edited by scandyflick
welcome :laugh:
if your interested in entrering shows and stuff im the SAU:SA Events Coordinator :D
thanks i'll keep it in mind but i think i should spend a bit of time and money on the car first before entering it in shows.
but thats the long term goal anyway, make it showy :D
I would, yes. Fit your EBC, get a retune, profit. If you could get some bigger injectors and a larger AFM while you're at it you'll make better use of the turbo but still, will be sweet regardless
Yep GT2871R will mean injectors 740cc, Z32 AFM, and a remap at the very least (at least the remap will only cost you around $600 including the daughter board) and to get the most out of that turbo you should really get cams. Without cam your looking at around 230rwkw and with cams your looking at 250rwkw. If you don't want that power then look at a GT28RS, that'll be around 220rwkw without cams and 235-240rwkw with cams. Standard SR's will take 250rwkw without a problem depending on how you drive it and how good the tune is.
EDIT!!
I'm pretty sure the use of any harness is illegal in SA.
Edited by D_Stirls
looks like ill just be getting the t28 rebuilt then, ive got other things i need to start getting the money together for. car has to be put on the back burner sooner or later.
cant justify the nigh on $2k.
i was told years ago (by regency) a harness is legal if you have the stock belt still bolted in and functioning.then i got pulled over and fined for not wearing a seatbelt,was using a 4point momo harness...and got the old Rx-7 defected at the same time for my troubles..
who knows really???
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
