any1 ever had problems putting a bolt on exhaust? cut the old 1 off yesterday and the bolts are stuck in the holes, rusted or something and my car sounds like a truck!!! (end of exhaust= end catback haha)....oh and we had to cut bolts because the old bolts were warn down and rusty.. had to drive it home...safe on private property :blink:
Just take it to an exhaust place mate and they will be able to sort you out in no time
if your lucky theyll defect you, or they could crush ya car for hooning - unnecessary noise section 250c
well better put on a good show then ay or il try talk my way out of it and explain what im doing.. i have to do it either way :blink: ive done all i can from home.. tried knocking it out, drilling it out and it did no use.. they wont crush for that anyway.. i hope
well at least you hope so....
just take back streets and baby the car as much as you can, short shifting, etc. if you just go straight to the closest mechanic i think most cops should be OK about it. I wouldn't do it if you cat isn't there tho as that could result in a very large fine. Also try RAA or a similar place that comes to you, just to get the bolts out/off and put a new system on yourself.
yeh cat is on there mate.. and yeh i chose the closest place.
Hi Peeps :blink:
Whats crackin in SA of late??
I cant find the thread about the new club...(yes I am lazy didnt search very hard)
How is it all coming along?
P.s Guess what!!! Went over to Tassie last month cause getting into Rally now and they have Farmers Union Iced Coffee in like every shop and servo...I was stocked! :P
Hi Peeps :blink:
Its going sweet, its all go. We have a full commitee in place now and the debut event is a dyno day coming up soon.
http://www.skylinesaustralia.com/forums/of...-D-t275144.html
Thats a very clean 33....used to belong to a mate of mine Murry
He lived around my area too and seen that thing around a fair bit.....definitely a good buy there
cheap as too, guy is heading overseas tomorrow, used it as bargaining power. should be able to convert it to manual for less than what he was asking
but yeah its mint
very nice i also managed to get my R33 from a guy who was moving back to Japan, go to love the bargaining power you have.
It still belonged to Murry you dork ;)
what is it...pick on the black kid now.....:)
yeah well since your mate said he had bought it, then it doesnt belong to murry anymore....hence "used to"
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
