What the hell is with the non iced coffee drinkers here?? its very unAustralian!
nicely said Penny. god damn un australian people
i dont enjoy any type of coffee.
you will die a horrible horrible death.
You wouldn't want to be around me in the morning if I skipped my coffee..... :thumbsup:
+1
unaustralian people drive DE's...
im now the proud owner of a set of blitz 550cc injectors...
... scratch that. im getting the nismo 740's instead...
Edited by scandyflick
i dont really mind spending the coin. only pisses me off a little. and ill get most of it back when i sell it. the only thing that bugs me is the time off the road.
atmo cars are boring as batshit. well, the affordable ones are. ferraris are quite enjoyable.
Complete set of Gates belts going on tonight (set of 4) ... fun times ahead removing the radiator and crank pulley :thumbsup:
Aren't cars awesome? :thumbsup:
Edited by RubyRS4
haha, i just talked krish into buying a turbo.
Which one?
I took that dump pipe to my local exhaust place, he made a gasket up then and there for me for $10, love local businesses.
Edited by Aberax
hypergear atr28-g3. i should totally get a commission for that shit.
I know and pretty damn cheap as well was so happy with it.
Now just waiting for an email and see what happens from there on....gota get a few custom bits made up and a awesome tune and walla....we are all good to go....hopefully can have it all done by the dyno day ohh yeah
cheers Dave
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
