What the hell is with the non iced coffee drinkers here?? its very unAustralian!
nicely said Penny. god damn un australian people
i dont enjoy any type of coffee.
you will die a horrible horrible death.
You wouldn't want to be around me in the morning if I skipped my coffee..... :thumbsup:
+1
unaustralian people drive DE's...
im now the proud owner of a set of blitz 550cc injectors...
... scratch that. im getting the nismo 740's instead...
Edited by scandyflick
i dont really mind spending the coin. only pisses me off a little. and ill get most of it back when i sell it. the only thing that bugs me is the time off the road.
atmo cars are boring as batshit. well, the affordable ones are. ferraris are quite enjoyable.
Complete set of Gates belts going on tonight (set of 4) ... fun times ahead removing the radiator and crank pulley :thumbsup:
Aren't cars awesome? :thumbsup:
Edited by RubyRS4
haha, i just talked krish into buying a turbo.
Which one?
I took that dump pipe to my local exhaust place, he made a gasket up then and there for me for $10, love local businesses.
Edited by Aberax
hypergear atr28-g3. i should totally get a commission for that shit.
I know and pretty damn cheap as well was so happy with it.
Now just waiting for an email and see what happens from there on....gota get a few custom bits made up and a awesome tune and walla....we are all good to go....hopefully can have it all done by the dyno day ohh yeah
cheers Dave
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
