I was going to but not sure If I can just yet.....
Aww ... it'll be fun just watching the men act like children :)
sausage wallet....LOL! :P
I have a female friend who's fav saying is "smash my sausage wallet" :D
Haha,
I did go karts with my family who used to ALL race bikes/cars/speedway and are the most competitive group you will meet. Who ever doesnt win has the best excuses. Its so funny.
Im used to the "childish" behavior in other words. :P
Looking at these "rally driving hot laps" and "V8 Supercar hot laps" you get about 7 laps for $350ish, i reckon Andrew and Chad could easily charge to take their car around the circuit :D
Yeah, and they lose all that income in Professional Indemnity Insurance ... along with application fees (for each participant), fuel, rubber etc etc :P
Anyone want a "hot lap" around Mallala on the back of a bike? :)
Edited by RubyRS4
Im used to the "childish" behavior in other words. :)
Same with me and my mates :D ... "coming second place is just being the first loser!" :P
I love hearing all the excuses on track days/practice days. One mate wanted low 1m20s at Lala but was running low 1m30s. Having a god-awful dummy spit about his suspension wasn't quite right and tyre pressures weren't right. He wasn't even going fast enough to even worry about fine tuning things :P I took it for a few laps and it ran fine for me ... a bit too street tuned with crap tyres, but still good for the 1m24s I ran with it. He got real f**ked off and packed up and went home. He's since been the butt of all trackday jokes since then :P
"My bikes not right. Something is wrong with it!"
"Well let me take it for a spin then you can go home!" :)
No thanks..... if there were pedestrians it might be entertaining however biggrin.gif
I'll have both hands on the bars ... so you just simply need to make a fist, and punch any pedestrians along the way :rofl:
Edited by RubyRS4
Oh, and the name is Ellen Page ... she plays Kitty in X-Men.
and an exceedingly creepy killer in hard candy.
I dont care if she looks like a boy, she has boobs and a sausage wallet that haven't been provided surgically.
:P
i dont even think mattys standards are that low.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
