yeah it says in the update that info will start to reappear.
Hi All,
Two days ago we introduced some new drives and raid controller as we kept running out of disk space. This morning that raid controller fell over and took one of our nodes (the most important one - the db) with it. We have replaced the raid controller and restored all data from a few-hours old backup. Sorry for the delays.
NOTE: As the uploads directory is 70GB, it is still being copied over. This means that most of the gallery and user uploaded files in the forums will be broken. Just give it time and it will return to normal.
Christian
it was so-so, SAU was down, so i went off and played on the ps3 most of the day. How about you?
um went to mildura today but cause i was feeling like crap didnt really enjoy the day like i should have :P
SAU seems to be missing a few post I think....
+1
What a joke, you know the saying though... a fool and his money are soon parted. Then again if you can afford those plates, you must have plenty of $$$
I love Holdens, bu there was some serious money thrown around to get this happening, i heard 3 million..
EDIT: for the last freakin time, who has the power to change my REAL name? godammit thats twice!
Edited by skwiz
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
