18x9 +20 and 18x10+18. I seen the car your getting yesterday with some CE28s but in a smaller size.. Looked okay but no where near as much dish as XD9's. There is nearly 100mm of dish on the rear!
how much for said rims?
dang, that's right .... there is no way they would fit .... the rears are 65mm wider than stock - they would hang about 3cm out of the guards :) .... 33mm wider than stock is the perfect number I am after, so 10" rims would need to be offset of +50
Yeah the CE28Ns I have priced and chosen don't have anywhere near as much dish as I would like, but they will have about 35mm dish which is the best I can hope for with this type of car.
EDIT!! Damo beat me too it
wheels on the Stag are already porn, 19" Racing harts FTW!! I was thinking for the 32, over the 34 rims now.
ATTESSA will chuck a hissy fit if you run staggered widths because no matter how hard you try you won't be able to achieve the same rolling diameter.
Don't believe me have a play;
http://www.1010tires.com/tiresizecalculator.asp
Edited by D_Stirls
because of the different stretch you will actually be running different rolling diameters so you will be slowly killing your clutches, the good thing is because the 32's don't run any preload you won't be wearing them as quickly as you would be with a 33 or 34 that run a proload.
Edited by D_Stirls
anyone know of a plastic welder in sa?
yeh i do mate
BUMPER TO BUMPER CRASH REPAIRS off tapleys hill road at Royal park
he did a great job on my series 1 m-spec bumper cutting out the middle section out and instead of leaving the cut out bit on the sides open he plastic welded a section in and it now looks flush
he is located in the western suburbs
Not cheap. So if your looking for <$2,500 no chance.
That's half the fun, making them fit. Camber might help tuck them in aswell.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
