Its shitful to hear how they're treating you Mitch. Ruby is spot on though, but would be very interesting to find out if their workshop carried any insurance? If it doesn't maybe thats why they said to you about your own comprehensive insurance?
Hope it all goes well for you mate and you can make some sense of all this disorder. Keep your chin up mate
i would if i could...
apparently my car has to have comprehensive insurance to be covered there and that their insurance doesnt cover it?
pm me if you like Pete
cheers Krishy :)
who says.......Dave & Mike??? :P
What if they only had your engine on their premises and it was stolen.......you can't comprehensivley insure an engine!
Speak to consumer affairs......your car was secured on private property, not driven on the road.
correct.
keys were in the ignition of my car and all the other cars in the shop which even if i did have comp insurance on it , wouldnt do shit...
What sort of workshop leaves the customers cars overnight with the keys in it???.....the only reason they are prob trying to say that your insurance will have to cover it is most likely because theirs is void as they didnt practise according to the agreement with the insurance company by leaving the keys in the cars....and since yours wasnt the only one they had left in the ignition makes me kinda sus.......
When i had my car at tilbrooks (back when they were open) my car was securely parked and keys properly locked away....now thats professionalism
if anyone can recommend or give me legal advice that would be greatly appreciated.
PM answered Mitch.
First step is to make a police report. List all damages/items stolen. You'll need a report number.
Second step is contact Legal Aid for some initial free advice. Ask them about the conditions of Liability Insurance and cover for the "cost of damage to customer cars". There should be Liability Insurance for such a situation, and you should be covered under such a policy.
Lastly, this will not be over in a short time. This can and will drag on for a lengthy time. The most likely scenario is that you will have to pay to get your car back on the road and can/will be reimbursed later. Keep all receipts/records of transactions.
Mitch thats crazt for the workshop to treat you like that !
wow, Im never going there
best of luck with it, you'll come out ok just will be a protracted effort by the looks of it
take ruby's advice - police report, legal advice
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
