They're really wide wheels man, the front sat nice with the guard when Jarad had just the fronts on,
Them wheels ^^ there aren't bad, awesome for the dish and yeah I agree they need the black centres otherwise too much chrome and look cheap and tacky, hmmm how much for them ^^
You getting your guards lipped?
Edited by Weezy
width doesnt concern me, width PLUS offset however, sorta does.
my old 8 +32's fouled on the spring perch. from memory, j's xd9's are wider with a similar offset, hello foulage. and im not going to run spacers.
haha, calling eurolines tacky? interesting. similar wheels to what i had on the celsior, def not tacky.
and yeah, rear guards have been lipped, ill do the fronts if i wind the coils down.
Edited by scandyflick
i feel like crumpet with butter and vegimeite.......wonder if stuart has eaten them all yet :)
yuk, too friggan salty
crumpets, better then pancakes but not as good as waffles.... the debate begins again...lol
how about french toast ???
My XD9's are 18x9+20 and 18x10+18. Lowest they make.
fairly sure the fronts will foul on my struts.
rears would be fine... i think.
call me a puss I cant stand it...lol
like eating a salt block, even after 9 years here I still wont eat it...lol
lol. pussy. maybe you oughtta try some of that pussymite stuff theyre marketing for you girlymen.
nah they will fit.. mate had this fittment on his s13.. no spacers and they were fine!!
DOO IIIITTTT
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
