Tint a car do Midnight Express, which apparently is the darkest legal tinting option! Heard good things about it.
Before Steve gets in, i think Ric from Auto Perfection does it too :D
no its not on the 2 front windows - i found out the hard way can be 35% all round but the front windows - no more than 70%
Cara is right i have the widow tinting brochure that i got when my car was being inspected.
Taken from the brochure:
The driver and passenger windows must have a luminous transmittance of at least 70%
The windows behind the driver must have a luminous transmittance of at least 35% unless they are interior windows
The inspector had a good look at the windows in the stag when i was there on Wednesday.
Edited by DSTROY
Umm all these damm rules. :D why can't things be simple.
Thank you for the suggestions. All windows bar the front two are done, the rears do look fairly dark though.
So possibly 70% fronts??
As Andrew has said you can't go past that QFM pads, I'm using the A1RM pads, they have unbelievable cold bite (I seriously couldn't believe it), and i have used them at Mallala and pulling low 1:20's and for 15 minutes and never had any fade. Also done 2 modern Reg' events and i still have another 2 days left in the pads, that's with a few hills runs as well.
They have a 1/2 price rears deal (through GSR RallySport, who's a trader on here) as well and i got free postage as well so that's front and rear 780 degree pads for $190 posted.
Im pretty sure the QFM's are not available for skylines atm. They wont have any for about 3-4 weeks :D
My fronts where nearly as dark as the back window on the Stag but i had to rip it cos i got defected, but i'll get them done to match the rears again cos legal tint will look to see though compared to the privacy glass.
70% to be legal, darker if you want to risk being defected.
so, had a bit of trouble moving my seat rail back and forward.
solution, absolutely packed it full of some random loctite grease. (i lol'd at loctite making a product designed to stop shit sticking)
still a bit firm, but whatever, probably just the rails expanded a little when they were being welded and bound up a tiny bit. no biggie, much easier to move than it was.
lol at passed out little guy
off to melbourne tomorrow morning to buy a yellow 02 ford escape for $5999
paid $500 and $90 for air flight. got unrego vehicle permit to drive it back
need to grab 2 tyres in melbourne, fill her up, then drive back.
long day tomorrow me thinks
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
