I wish! Don't know whether to go for a FMIC first or suspension. All too hard cause I don't want to cut reo and cop a defect either!!!
I got to go speak to a suspension expert about lowering my car because I definitely don't want a harsh ride, being a daily driver. If I can get it 25-30mm lower with spring rates very similar to what they are now and of course correct camber I'll be happy.... don't really think it needs to be any lower than that.
do what i did. do it all in one hit. lol.
ill take you for a quick spin in the s14 some time, its firm, but it isnt harsh. and thats with my unpadded fibreglass seat. lol.
or you can go and spend big on bilstein gear, which going from nightcrawlers gear, is actually harsher than my coilovers.
A good puncture repairer can drill and glue a plug in there
yeah, ill see what tyrepower can do when i get it aligned on saturday.
test fitted the rims last night at grand auto....bolt straight on..rears need spacers to bring them out to the guard....they are APEC
i just need to swap two of the tyre over as they are 205/40/17...ill put my 217/45/17's pn for the back
Link didnt work for me Damo????
With the summer weather coming up steve i would be looking into a FMIC....i remember the days when i drove my 33 in the summer with the side mount and compare that to the same weather with a FMIC its unreal....FMIC does such a good job
I'll have to do it bit by bit so I can still drive it to work! We'll have to organise to go on another cruise up the hills.
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :D
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :P
Yeah my car runs the stock SMIC, last summer one afternoon when I was driving to work and my car said it was 45 degrees, I went to overtake someone on a fast road after they turned off, my RB20 felt more like a RB10. Thats without A/C on because it doesnt work lol. So needless to say, a FMIC is on my list - along with heap of other stuff.
im looking at hookin up a small electric water pump to my washer bottle with some little garden water sprayers between the cooler and the rad for some extra coolness when it all gets a little warm.
dave-o, Jenkies just ran his window washers to the fmic, so when you pull back on the stalk to squirt water, your spraying yo cooler not yo window!
That's cool (no pun intended)! Then in winter you can plug them back into the bonnet squirters :P
or re route them to the back wheels and join ragerz :P
damn you got to it before me.....i was thinking why not just tap into the hose that runs from the washer bottle to the jets.....that way spray the cooler and clean your window at the same time
cos when your cranking at 160 k's down the back straight at lala, the last thing you need is a front window full of water and your wipers going all frog in a blender
true true that.....Dave when you do this thingo let me know what is needing to be done
Where can you buy hobbs switches??
Im working out with our electrician how to do intercooler water spray kit and i beleive all i've got left to get is hobbs switch and reservoir/pump which is the easiest bit
Easy man, go down to bunnings and grab some spray nozzles from the garden section, then run your existing water hoses and cable tie them (so the nozzles spray in the right direction) underneath or on top of your cooler.
I dont actually have a washer reservoir :P FMIC piping took priority, gotta get the mrs brother to fab one up for me.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
