I wish! Don't know whether to go for a FMIC first or suspension. All too hard cause I don't want to cut reo and cop a defect either!!!
I got to go speak to a suspension expert about lowering my car because I definitely don't want a harsh ride, being a daily driver. If I can get it 25-30mm lower with spring rates very similar to what they are now and of course correct camber I'll be happy.... don't really think it needs to be any lower than that.
do what i did. do it all in one hit. lol.
ill take you for a quick spin in the s14 some time, its firm, but it isnt harsh. and thats with my unpadded fibreglass seat. lol.
or you can go and spend big on bilstein gear, which going from nightcrawlers gear, is actually harsher than my coilovers.
A good puncture repairer can drill and glue a plug in there
yeah, ill see what tyrepower can do when i get it aligned on saturday.
test fitted the rims last night at grand auto....bolt straight on..rears need spacers to bring them out to the guard....they are APEC
i just need to swap two of the tyre over as they are 205/40/17...ill put my 217/45/17's pn for the back
Link didnt work for me Damo????
With the summer weather coming up steve i would be looking into a FMIC....i remember the days when i drove my 33 in the summer with the side mount and compare that to the same weather with a FMIC its unreal....FMIC does such a good job
I'll have to do it bit by bit so I can still drive it to work! We'll have to organise to go on another cruise up the hills.
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :D
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :P
Yeah my car runs the stock SMIC, last summer one afternoon when I was driving to work and my car said it was 45 degrees, I went to overtake someone on a fast road after they turned off, my RB20 felt more like a RB10. Thats without A/C on because it doesnt work lol. So needless to say, a FMIC is on my list - along with heap of other stuff.
im looking at hookin up a small electric water pump to my washer bottle with some little garden water sprayers between the cooler and the rad for some extra coolness when it all gets a little warm.
dave-o, Jenkies just ran his window washers to the fmic, so when you pull back on the stalk to squirt water, your spraying yo cooler not yo window!
That's cool (no pun intended)! Then in winter you can plug them back into the bonnet squirters :P
or re route them to the back wheels and join ragerz :P
damn you got to it before me.....i was thinking why not just tap into the hose that runs from the washer bottle to the jets.....that way spray the cooler and clean your window at the same time
cos when your cranking at 160 k's down the back straight at lala, the last thing you need is a front window full of water and your wipers going all frog in a blender
true true that.....Dave when you do this thingo let me know what is needing to be done
Where can you buy hobbs switches??
Im working out with our electrician how to do intercooler water spray kit and i beleive all i've got left to get is hobbs switch and reservoir/pump which is the easiest bit
Easy man, go down to bunnings and grab some spray nozzles from the garden section, then run your existing water hoses and cable tie them (so the nozzles spray in the right direction) underneath or on top of your cooler.
I dont actually have a washer reservoir :P FMIC piping took priority, gotta get the mrs brother to fab one up for me.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
