I wish! Don't know whether to go for a FMIC first or suspension. All too hard cause I don't want to cut reo and cop a defect either!!!
I got to go speak to a suspension expert about lowering my car because I definitely don't want a harsh ride, being a daily driver. If I can get it 25-30mm lower with spring rates very similar to what they are now and of course correct camber I'll be happy.... don't really think it needs to be any lower than that.
do what i did. do it all in one hit. lol.
ill take you for a quick spin in the s14 some time, its firm, but it isnt harsh. and thats with my unpadded fibreglass seat. lol.
or you can go and spend big on bilstein gear, which going from nightcrawlers gear, is actually harsher than my coilovers.
A good puncture repairer can drill and glue a plug in there
yeah, ill see what tyrepower can do when i get it aligned on saturday.
test fitted the rims last night at grand auto....bolt straight on..rears need spacers to bring them out to the guard....they are APEC
i just need to swap two of the tyre over as they are 205/40/17...ill put my 217/45/17's pn for the back
Link didnt work for me Damo????
With the summer weather coming up steve i would be looking into a FMIC....i remember the days when i drove my 33 in the summer with the side mount and compare that to the same weather with a FMIC its unreal....FMIC does such a good job
I'll have to do it bit by bit so I can still drive it to work! We'll have to organise to go on another cruise up the hills.
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :D
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :P
Yeah my car runs the stock SMIC, last summer one afternoon when I was driving to work and my car said it was 45 degrees, I went to overtake someone on a fast road after they turned off, my RB20 felt more like a RB10. Thats without A/C on because it doesnt work lol. So needless to say, a FMIC is on my list - along with heap of other stuff.
im looking at hookin up a small electric water pump to my washer bottle with some little garden water sprayers between the cooler and the rad for some extra coolness when it all gets a little warm.
dave-o, Jenkies just ran his window washers to the fmic, so when you pull back on the stalk to squirt water, your spraying yo cooler not yo window!
That's cool (no pun intended)! Then in winter you can plug them back into the bonnet squirters :P
or re route them to the back wheels and join ragerz :P
damn you got to it before me.....i was thinking why not just tap into the hose that runs from the washer bottle to the jets.....that way spray the cooler and clean your window at the same time
cos when your cranking at 160 k's down the back straight at lala, the last thing you need is a front window full of water and your wipers going all frog in a blender
true true that.....Dave when you do this thingo let me know what is needing to be done
Where can you buy hobbs switches??
Im working out with our electrician how to do intercooler water spray kit and i beleive all i've got left to get is hobbs switch and reservoir/pump which is the easiest bit
Easy man, go down to bunnings and grab some spray nozzles from the garden section, then run your existing water hoses and cable tie them (so the nozzles spray in the right direction) underneath or on top of your cooler.
I dont actually have a washer reservoir :P FMIC piping took priority, gotta get the mrs brother to fab one up for me.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 🤣, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
