Easy man, go down to bunnings and grab some spray nozzles from the garden section, then run your existing water hoses and cable tie them (so the nozzles spray in the right direction) underneath or on top of your cooler.
I dont actually have a washer reservoir :P FMIC piping took priority, gotta get the mrs brother to fab one up for me.
Wicked.....
Thats odd....with my greddy FMIC i was able to retain the stock washer bottle.....interesting
After having a very pleasant 69 with his girlfriend, George remembered
he had a dentist appointment.
He was afraid the Dentist would notice the smell of fanny on his breath,
so he brushed his teeth, used dental floss, and also used a whole bottle
of Listerine.
As he arrived at the Dentist he also ate a whole packet of extra strong
mints.
His turn came up and the Dentist told him to take a seat in the chair.
Feeling confident and relaxed he opened his mouth wide.
The Dentist got close and asked " So, you had a 69 before you came here
eh?"
Brian exasperated asked " How did you know? Does my breath still smell
like fanny?"
The Dentist replied " No...you have a skidmark on your
forehead..........."
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
