lol. yeah, no more knock on take off either. pain in the ass driving with shot mounts. knocks at every opportunity, crunches when you snap a gear...
... all sorted now though. :thumbsup:
the only car this weekend ive heard with a knock since was nathan's lol............yep, nice bottom end rattle
firstly, my only poisons are booze and cigarettes
i decided to perform a social experiment with my housemate "milky".
milky loves his weed, but he hates spiders so i set this lil trap for him
i'll let you all know what happens when he gets home :)
Genius :thumbsup:
I don't smoke weed, but if they were my cigs in there.... you can have them! I fkn hate spiders :)
Hmmmmm decisions, decisions ....
Both 25,000km(ish)
Blue = full leather, TV, front lip, CE28Ns (but not tuff enough offset), full stainless exhaust with titanium tips, stainless intake pipe, thrashed??
Red = half leather, TV, sunroof, cleaner engine bay, stock, not thrashed, $3k cheaper
I can't decide .... damn buying a car is hard work ..... especially after the one I had settled for didn't work out, and there are no more auto black sedans for sale in the country (and I dislike all the other sedan colours).
Opinions?
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
