Love the city one "obviously got nothing better to do", who's the sad feck crying about it to the advertiser? lol
Thats what gets me, people who live near the city or the airport that constantly complain about the noise. I bet 80% of these complaints are lodged by old people with nothing else better to do. Bit like the old fart that complained to the council about my dogs barking, four dogs of the same breed in the block!
i got egged last weekend unfortunately had the door open at the time, got the f er's plate n called the cops but they didnt really seem interested.
shoulda just said he was doing burnouts instead they woulda been knocking on his door in no time.
just bought a new oil cooler..
do i fit it with or without oil? how much oild do i put it in if i dont fill it first? CA18DET..
also when im tracking the car and the catch can fills with oil do i put the oil back into the engine or dump it?
cheers
cheers
do it without oil, just fill it to the normal spot on the dipstick, and dump the catch can oil.
I change my oil every track day or dyno day.
belgian beer is by far the best beer ever!! so much awsome drunken times in my life are thanks to belgian beer!
exactly, like rocking up 2 hours late to my birthday when u lived the closest LOL
on another note, EVENING!
Who is going to, or would like to go to, the V8 Supercars at Phillip Island 11th-13th September? :(
It appears I'm going alone ... but would like to share the driving if someone else is trekking over. I might be able to get someone in on a guest pass, as I'm working there.
Anyone? :)
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
