now that is some funny shit hahaah
Yep, having watched the normal AND the Unrated versions of Sex Drive - top movie in both forms! The beauty of the unrated one is the random naked chicks running through the set for no apparent reason every so often .... classic.
what happens if you plug up both breather on an engine ;) what can break/fail/die?
what happens??? a small somalian child dies...thats what happens.......
actually...its not good to block both breathers...thats why they are called breathers....its part of the crank case ventilation system..you block them off and the vapours caused by the cavitating oil in your sump will try and find the easiest way out...which means your timing cover and rear main oil seals will be the first things to leak....
actuall it surprises me how coherent i am this time of the morning without my coffee :D
Is it just me who is getting no reponse (not loading, page cannot be displayed etc.) from the SAU website sometimes in the last week? like 2-3 minutes ago?
I get it all the time. I'm sure the gurus are working on it.
every now and again it takes AGES to load, but only stalls for about 2 mins and is then back up.
Okay cool, so its not me then. Ive been having a few dropouts lately which I never had before, but its obviously un-related and also I cannot access anything when it does it.
Okay Im off to bed, last nightshift tonight... THHHHHAAANNNNNK GODDDDDDDDD
anyone else a big fan of dexter? love it! got S1 and S2 at home, almost finished season 1.
awesome show, i finished season 3 earlier this year
season 2 was the best imo, the ending is brilliant!
the show's addictive - if you start watching it a few episodes into a season (on TV) [edit - i reccommended it to friends of mine and they couldnt get into it], you wont be interested. gotta watch it from the start!
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
