yep! i get sucked in to TV series, i gotta get Burn Notice season 2 back out to watch. i know its on tv at the moment, but i prefer watching seasons all in one session :D
same here. love Burn notice too, quality show! it's up to episode 9 in season 3 atm, with a total of 16. the last 7 episodes will be run in the winter season (in the US - so December). E9 is a good mid-season ending - leaves you in suspense!
Holy crap, a SD camera card 2 terabytes in size is available soon. lol
SDXC
The Secure Digital Extended Capacity (SDXC) format was unveiled at CES 2009. The maximum capacity defined for SDXC cards is 2 TB (2048 GB). SDHC cards also have a maximum capacity of 2 TB based on the card data structures, but this is artificially limited to 32 GB by the SD 2.0 document.
The maximum transfer rate of SDXC was announced as 104 MB/s, with plans to increase it to 300 MB/s in the future. The SDXC specification has selected Microsoft's proprietary exFAT file system as the standard for this memory card format;[24][25][26] however, as with SDHC and SD, it is possible to use another filesystem such as FAT32 or ext2.
One morning at a doctor's surgery a patient arrives complaining of serious back-pain. The doctor examines him and asks him "OK, what happened to your back?"
The patient replies "You know that I work for a local night club? This morning I got home to my apartment early and heard a noise in my bedroom. On entering I knew someone had been with my wife and the balcony door was open. I rushed out the balcony door and did not find anyone. As I looked down from the balcony I saw a man running out and he was dressing himself. I grabbed the fridge and threw it at him,That's how I strained my back"
The 2nd patient arrives looking as if he has been in a car wreck. The doctor said "My previous patient looked bad, but you look terrible.What happened to you?"
He replied, "You know I have been unemployed for a while now. Today was the first day at my new job. I forgot to set my alarm and was running late. I was running out of the building, getting dressed at the same time, and you
won't believe it but I was hit by a fridge."
The 3rd patient arrives; he looks even worse than the other two patients do. The doctor is shocked.
Again asks, "What happened to youuuuuu.....?"
"Well I was sitting in a fridge & someone threw it from the 3rd floor"
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
