yep! i get sucked in to TV series, i gotta get Burn Notice season 2 back out to watch. i know its on tv at the moment, but i prefer watching seasons all in one session :D
same here. love Burn notice too, quality show! it's up to episode 9 in season 3 atm, with a total of 16. the last 7 episodes will be run in the winter season (in the US - so December). E9 is a good mid-season ending - leaves you in suspense!
Holy crap, a SD camera card 2 terabytes in size is available soon. lol
SDXC
The Secure Digital Extended Capacity (SDXC) format was unveiled at CES 2009. The maximum capacity defined for SDXC cards is 2 TB (2048 GB). SDHC cards also have a maximum capacity of 2 TB based on the card data structures, but this is artificially limited to 32 GB by the SD 2.0 document.
The maximum transfer rate of SDXC was announced as 104 MB/s, with plans to increase it to 300 MB/s in the future. The SDXC specification has selected Microsoft's proprietary exFAT file system as the standard for this memory card format;[24][25][26] however, as with SDHC and SD, it is possible to use another filesystem such as FAT32 or ext2.
One morning at a doctor's surgery a patient arrives complaining of serious back-pain. The doctor examines him and asks him "OK, what happened to your back?"
The patient replies "You know that I work for a local night club? This morning I got home to my apartment early and heard a noise in my bedroom. On entering I knew someone had been with my wife and the balcony door was open. I rushed out the balcony door and did not find anyone. As I looked down from the balcony I saw a man running out and he was dressing himself. I grabbed the fridge and threw it at him,That's how I strained my back"
The 2nd patient arrives looking as if he has been in a car wreck. The doctor said "My previous patient looked bad, but you look terrible.What happened to you?"
He replied, "You know I have been unemployed for a while now. Today was the first day at my new job. I forgot to set my alarm and was running late. I was running out of the building, getting dressed at the same time, and you
won't believe it but I was hit by a fridge."
The 3rd patient arrives; he looks even worse than the other two patients do. The doctor is shocked.
Again asks, "What happened to youuuuuu.....?"
"Well I was sitting in a fridge & someone threw it from the 3rd floor"
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
