Got a spare 23k burning a hole your pocket ?????
- Brand New R33 GTR N1 Long Motor
- Fully Assembled
- All Components Brand new
- Ready to Install
- 500PS Package
Engine Package Includes:
- Front Differential
- Sump
- Tomei 1.2mm Metal Head Gasket
- Tomei Metal Intake Manifold Gaskets
- Tomei Metal Exhaust Manifold Gaskets
- Tomei Poncam Type B Camshafts (260 Deg/9.15mm)
- JJR Adjustable Cam Gears
- Sard 700cc Injectors
- Sard Dual Entry Fuel Rail
- HPI Stainless Dump Pipes
- SSI Premium Stainless Exhaust Manifolds
- HKS GT-SS Twin Turbo Kit
- Gates Strengthened Silicone Timing Belt
- Trust Clear Timing Belt Cover
- Nismo Engine Oil Cooler Sandwich Plate
- Nismo Engine Mounts
- JJR Direct Ignition Coil Packs
- NGK BCPR6EIX-11 Iridium Spark Plug Set
- N1 Oil Pump
- N1 Water Pump
- Cooling-Pro Silicone Water Hose Set
- Ceramic Coated Plenum
- R34 GTR NUR Coil Cover Emblem
- HKS Oil Cap
- New Genuine Nissan Air Regulator
Engine Internal Specifications:
Displacement: 2568cc
Bore: 86mm
Stroke: 73.7mm
Compression: 8.5:1
Block: N1
Pistons: N1
Conrods: N1
Just Jap
Got any pics Dale? Looking for a more "fitted" rim for my 31, has some sort of 4 stud Nissan rims on it with a very high positive offset.
I also have some 17x7 rims that you can have for $550 they are copies of the rims i have on my 180 (Volk GT-P's), they have 3 legal tyres on them and one that has to much camber wear. I was going to use the 17's fro track rims but now that i'm fitting a RB25 i'll be going 5 stud.
Here's the pics 17x7's on the LHS and 15x6.5 on the RHS;
Edited by D_Stirls
ruby, malpassi's are know for making the squeeling noise on startup. sometimes from new. havnt had any fail on me, but i wouldnt doubt they do. personally i like aeromotive. has yours got a black or silver top? black is 1.7:1, silver is 1:1
I think my car is the anti christ! Just finished new pads and rotors, gearbox oil, diff oil, engine oil and filter change and a good wash down under the bonnet. Take it for a spin last night to bed the rotors and pads in, and discover i now have another coolant leak! Seems to be coming from around the water pump, that was only put on 10k ago! Hoping its just a loose bolt and not a shagged pump!
yeah i know what thats like
i got a new isc52mm radiator, n1 water pump, racing hose and nismo coolant put in earlier this yr
next day i lose 20% of my coolant via a cracked hose in the heater core (back of the engine, real pain in the arse to get to)
ahh well
two steps forward, one back - always the way with the older cars
-D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
