Abe, place the pump in the exact same position as your stock one. Make sure the bottom of it is inline with the stock one. Looks like u will need to cut the hose alittle shorter and connect that up. Cutting the bottom bracket off is fine as u need to. After that hose clamp it on and slide it into place.
I am slowly getting there with the pump.
I finally stuck my whole arm in there and managed to get the pump into position, that was with out hose clamping it to the cradle. I have now hose clamped it, cut the tail off...just waiting for it to stop raining, while having lunch.
Also, petrol melts the sound deadening in the Tyre well.
mitch, i dont think a 26 head gasket will go on a 25, they have different oil lines
the gaskets will be the same appart from that the 26 will have larger holes where that head studs. The proof is that with 25-26/30 conversions both the 25 and 26 head will fit the 30 block without modifications.
i wasen't quite sure, because the 26 has an oil feed to the head blocked off where as the 25 keeps it (for vvc)... so wasent sure if the head gasket for the 26 still has the hole for the blocked off feed or not hence played it on the safe side. Tho isn't the hole a different shape on the 25, smaller and tear drop shaped? but probably wouldnt matter since the 26 hole would once again be larger...
need the chains coming off the back now so u dont run them over.
thats the next bit im working on, definitely going to need them when i do the fronts thats for sure
lol. plenty of 'otherwise inclined gentlemen' in adelaide. (i got majorly chewed out and refused service from the ex lady for refering to a fag as something rather crude today, lol)
most of them hang at hq on wednesday nights. makes it real easy to throw some moves on the rather large amount of easy ladies that frequent slash dance.
needs more twink reference haha
hmm... just found the same set of wheels i want (albeit in a different colour, and without tyres) brand new for $90 more than i was gonna pay for use ones... really not a fan of the colour though...
was just reading a thread on ns.com
1800 defects in the last 8 days!! hahaha WTF!
would like to know what suburbs this is happening in!
i know the west subs have cops galore!
You said they said they heard? NS.com is hardly a reliable source. :down:
I have a soft spot for Capellas lol,
So badly want something old school Mazda with a 13bt in it.
Or a ke10 with a 13BT
Faaark yeah the 200m powerskids would be awesome
Edited by Weezy
Many years ago, I helped a mate fit a 12A into a KE10! Last I saw of that project he was getting it wired up. Don't know how far he got. But even a 12A in something as small as that would have been fun!
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
