yeah Dan, not just any RB30, but OS Giken RB30 .... just the blocks alone are $30k .... and he has bought many of them .... still has a brand new one sitting under his workbench under a sheet if I remember correctly ....
and given all that coin RIPS are making the same power and pulling 10,000rpm on a dirty old VL 3 litre block that cost $100. :/
Infact give RIPS NZ$19,500 (less 20% for exchange rate) and they'll give you a 1100+HP ready completely engine.
http://www.ripsltd.com/products.html
Edited by D_Stirls
adding to that an OS Giken quad plate clutch at around 4-5k, an OS gearset at around $6-7k, then you got a bottom end, clutch and gearbox, around 50k later, haha.
I got my OS gearset for 5k new
what do yas think about the Ogura Racing Clutch's yet to use mine heard good feedback but
what is everyone's thought on these if you have used them b4.?
i have an orc twin plate, and i love it. had an unknown brand heavy duty clutch in the old girl when i got it. the orc has ass loads of clamping force, the friction point feels really exact and its not too hard to drive with (my gf drives it easily, and to my knowledge only stalled it on the first 2 attempts to get off the line)
and given all that coin RIPS are making the same power and pulling 10,000rpm on a dirty old VL 3 litre block that cost $100. :(
[sexy image]PORN[/sexy image]
what a sexy bit of kit that is!
hey kye, wait a few months and buy the 200.
hey mate, my friends just bought a car today. a car that a guy said was sold came back up and he snapped it up.
sorry man
damn sell out
ill give ya 5 for it, need something to drive to work :)
you can give me 5 and the gtr and maybe a blowie and only then ill consider letting you take it :)
Buy Jon's VR4 Kye!
he would never sell it and id never buy it so he keeps it forever :(
nah just picked it up before but its just a gun metal grey r33 coup
got it pretty cheap at 9.7k. has a really thick cooler, short shiter, gauges, full exhaust, impuls, heavy clutch, stealth wing and a few other things.
really really clean though!
lol. lot less than he woulda got the 200 for. :(
sounds like a decent buy.
yeah not to bad, picked me up before to get food and i got to drive it.
sounds pretty tuff and has alittle bit of balls i guess :)
FFS, anyone know wtf is going on with the fs section on ns :)
was working for me before both cars and parts
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
