hey all, just putting the word out, a mate of mine is looking to swap his BA xr6 turbo + cash his way for a decent 32/s13/200
it has:
*fmic
*3" zorst
*flashtune
*with flash tuner
*monza custom air box
*pod
*tiptronic
*makes about 260rwkw
if u want moar info pm me :(
haha r32 w/rb25det..
yes yes i have bought a toyota.. just got a nissan engine :P
Check the voltage of your battery whilst car is on (alternator charging) If it's below 14v or so, then you've got a problem.
Dale's brother.
No he can do the slotting but he can't do the machining as both sides have to be done in the same setup and with a CNC you can only work on one side per setup.
Luke from memory the machining was around $25+GST each last time i got mine done.
i still dont have any pics, lol, but im heading out for grip in the 34 soon, only bought the 31 coz i was selling the 34, but now im keeping it, the 31 will probably be up for grabs after i fix its little demon (something draining the battery)
1989 R31 Series 3 silhouette, painted S15 pewter
was told it has around 45000k's on the RB20DET, but i dunno how reliable that info is. Is registered (been through regency) with the RB20. brakes would have been upgraded for the engine swap, but the previous owner couldn't tell me what exactly they were upgraded to.
RB20 gearbox
heavy duty clutch
Cusco strut brace
battery relocated to boot
FMIC with custom hard piping, some sort of BOV attached, all plumbed into the system tho, mad flutters.
dual core radiator
vented catch can
Jaycar boost controller
Remapped R32 Ecu
aftermarket guages, oil pressure, volts, boost, water temp and tacho.
the usual audio upgrades
i think thats pretty much it.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
