Will i need the slots put back in once i get them machined? i got him to slot them last time.
no they will only take off a fraction of a mm when the machine them and Matt generally slots them deep enough that the rotors will be stuffed before you get to the bottom of the slots.
You know of any pictures floating around?
What made you want to keep the 34?
Actually i do have these pics that he sent me when i first enquired:
Keeping the 34 because i realised i kept talking myself into wanting to sell it, had no real reason for it. I mean shit, you're only young once!
Yeah your 34 is mint as gosh darn lol, good call.
Got a price in mind for when you sell the 31?
___
Aha, shes not a bad looker either Dan :P
Edited by Weezy
thanks man, i really do love the 34.
when i fix it, the battery wont drain when its off, and all youll need is someone to wind the boost up. The Jaycar boost controller connects to one injector, and theres a few values to adjust, so its not as simple as turning a knob or pressing up. Dunno on price, still gotta transfer it into my name, throw some rego on, maybe 4200ish?
Damo when are you taking the 34 for the grip session.....keeen to take the 33 out there as well
now need to get a helmet......anyone know of a good cheapo one thats approved for the track
rofl...carsguide published my entry to try and get my wife to be a test driver for the new FPV...
My wife, Nicky has been an avid ford lover all her life, From growing up around a drag racing father who had an XA GT to nowadays owning her AU Fairmont 5.0. Her dream car is the mighty XY GTHO which with our budget is completely out of reach .I would love for her to have the opportunity to "test" (re flog) a new FPV, i believe it would fulfill one of her goals in life
Ben Bradley of Woodcroft, South Australia Posted at 02 September 2009 4:44pm
heres hoping she wins
f**k yeah my GTR f**king lives again. :):);):woot:
After 9 long months of doing sweet f**k all in my driveway, never turned on... fired up first pop today! No smoke, no funny sounds, no bullshit.
Pulled off the error codes: 2 dead Oxygen sensors. Getting them replaced as I type this.
Throwing her on the dyno tomorrow for a good solid run, tune and checking of the fuel pump, etc.
FINALLY. It's been too f**king long.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
