Ok well in easy to understand terms.
I push the power button on, the fans start up and the keyboard lights up for a second, then goes out. The mouse doesn't light up. There's no beeps like there usually is, just the noise of fans spinning.
I've unplugged the screen at the back and a message comes up saying connect back up, but the light next to the screens power button keeps flashing.
hey abe, u got msn? wanna chat about my comp :bunny:
yes, yes i do. It is in my profile.
Could be a few things.
1. GPU (Video Card)
2. Mobo
3. Ram - unlikely, but i have seen stranger things.
spend the day 'installing' krish's new turbo. bit of a head f**k.
only 3 out of 4 of the nuts for mani-turbo studs would screw on because one kept fowling on the housing, so thats off to be machined this week, and the wastegate design sucks. flap opens about 5mm before it fouls, so ive taken it to andrew and it looks like itll be getting the internal blanked off, and an adaptor for extrernal gate made up.
anyone got any hookups for tial 44mm gates?
I was gonna sms him and ask him how you guys went, but you just summed it up for me. Lucky he has a daily...unlike me, but i am due for a bit of a holiday. My upgrades should be getting done soon, say 1-3 weeks. I am going to go through Horsepower In A Box, as it is just round the corner from my work...sort of.
Edited by Aberax
it went alright. had a few moments where we were missing a few odds and ends, but it went pretty smoothly until those 2 issues popped up. wouldve been about a 4 hour turnaround. with any luck he'll have it back on the road within 2 weeks.
Split dump wasn't it? They are what suck not the wastegate.
Bellmouth FTW
i use those gauges too. pretty accurate. shall have to get a few more soon.
Bellmouth FTW
negatory. no split dump. kinda hard to explain, but theres another piece that bolts to the back of the turbine housing that holds the wastegate flap and has the vband for the exhaust flow on it, problem is this section is shallow for the wastegate flap to properly open.
Edited by scandyflick
I know what yoru talking about, it's a shit design i can't see how you can't get boost spiking with that setup.
What turbo is he using?
Hey Dale, are these the guages you use?
Yeah thats the gauges that i use, if you want a set matt can get them through his business.
its garbage. i was expecting a few things to be not quite right, but thats just shit.
its a hypergear tr28 or some such. part of it is sitting on my desk, half of it is at krish's place, the rest of it is at am performance waiting for krish to give the ok to fix it.
and on the topic of gauges, ill be speaking to you soon about a couple oil gauges.
So who's good with computers? My home comp won't load anything. You turn the harddrive on but it just looks like it not doing anything, only thing moving is the fan :( . The light on the screen just keeps flashing so it looks like it's not loading the hard drive arr help plz
i have tomorrow off if you want to bring it over, I'll sort it out
on other news, go rear ended today on the way home from writeoffs place
chick decided to step on the gas when the lights went green - i think she assumed i was going to gun it ;P looks like minor damage only (paint and one of the plastic clear reverse light covers) but won't know for sure till my mechanic gets a decent look at it - went straight to holden hill to report it - cop there was cool as, told me about his xr6 turbo and came out to scope the car - said I had nothing to worry about as far as defects was concerned, which is great news (considering thats my aim) and also said that I'd got a nice example and was good to see someone taking care of their ride >:) *thumbs up to holden hill branch*
-D
Abe I'm 99% sure it's the video card. It stuffed up about a yr ago, replaced with a second hand one where the fan wasn't working properly for it.
Any idea where to get a basic video card from? Don't use the comp for games etc so just need a basic one.
Cheers.
No worries let me know when your ready
Cheers.
go to MSY - they pretty much have the cheapest retail sales in the state
-D
^ That sucks balls Ben. Hope she's insured....?
not sure - it wasnt her car - she said she doesnt know if the car in insured but would pay me cash for the repairs - i got the cop to check her details up and it all comes up as legit so I don't think I'll have to worry about dodgyness
6 weeks before the show too. none to pleased
-D
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
