i now have a box of stupidly expensive earls bits and pieces to go on the s14. just gotta pic up one more adaptor fitting from outlaw, and 2 90 degree bends from somewhere else and ill fit it all up.
Edited by scandyflick
Did you get it all through Outlaw's Dave?
hey all.
does anyone have an account with motor traders? can get cheap parts?
need 4x hec716 (ls1 coilpacks)
going external setup on the CA18det..
if anyone has hook ups let me know :P
also,
took my car to get some work done/oil cooler fitted. picked up the car and oil cooler lines were cut to "make them fit better (too long apparently)"
once they were cut the workshop couldnt get fittings to go on them so now i have an oil cooler with cut lines and nothing to connect them with..
what can i do? claim them against the business?
cheers
You won't be able to claim against the workshop as they will say that the problem was caused by the cheap lines. if they had provided the parts then you would have a claim. bring the lines to me and i'll get the fittings on them.
Gotta love the justice system.
The police caught the guy who broke into my parents rental property, got locked up but then released on bail a day later. Found out he was released last week on bail for beating a guy up. They can't lock him up for longer as this offence is totally different to the others.
What a load of shit.
Hey guys I have a quick question, I did search and did find an answer but I just wanted to see if anyone has a difference of opinion. If I am fitting aftermarket CF N1 Vents to an aftermarket FG bar, what is the best method of holding them in there?
Cheers :)
nice big plume of black smoke across the northern burbs - pgs (plastics granulating factory) has caught fire in kilburn
i could see the plume from semaphore... 30 metre tall flames as i drove past.... fireys are worried cos there are lpg tanks nearby and folks have been evacuated from their houses... looks like every cop in adelaide is down there
sooooo
go for a cruise if you're bored, they got bigger fish to fry tonite lols
-D
Unfortunately, thats a (fair) case of innocent until proven guilty. Until the court case prosecutes him, any further (accused) offences are to be treated without prejudice. Why cop the second offence harshly is you're innocent of the first offence?
Thats just the way things work.
I know what you mean tho. A close friend was killed in an auto accident by a crim who was on bail for murder at the time. His first offence (altho prosecuted for it) was not taken into consideration in sentencing him for killing my friend. He got 7 months added onto his already 7 years (for murder)!!! So he basically got a freebie before going to jail. FAIL
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
