balls. internet is running so f**king slowly. but ive got 8gb left til i hit my cap apparently.
cleared history, cleared cookies, reset router, still running slow as all shit. any ideas?
Sync speed & snr?
Grab a test file to see what sort of speeds you're downloading at, if your ISP doesn't have any grab one of internodes http://mirror.internode.on.net/pub/test/10meg.test
hmm - wilall told me they wernt interested in tuning the stag
Thats funny. I was told some weeks ago to bring mine in for a tune because they have their new 4WD dyno. ;)
i wasnt asking wilall for a tune, was asking their opinion on a problem...?
Sync speed & snr?
snr?
downloading test file at the mo.. 6kb/s. fail.
Modulation on router on the correct setting?
can i get that in computer stupid? (aka, english)
Edited by scandyflick
You can access that setting in the routers home page... usually found at 192.168.1.1
If your on adsl2+ usually the modem/router likes that setting better than mmode or gdmt. Might not be the issue either.
Incidentally I'm surprised moderators haven't stumbled across the threads in the ' General Automotive Discussion' section of the forum..... LOL!
yep, thats pretty bad.
You can find yor sync speed in the modems config pages too, normally under something like statistics/line settings
If you're syncd well above 6kbps then it's time to call your isp to see wtf is going on, could be backhaul issues or incorrectly shaped, if the sync speed matches the download speed then it's also time to call your isp and lodge a line fault.
Which ISP btw
adelaide blows. had a friends going away party tonight. got refused from 2 venues ive never been to before because my footwear 'wasnt up to standard'.
are you f**king kidding? how the f**k can a glorified pub have a goddamn dress code? sorta killed what was shaping up to be a decent evening.
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. ;)
Coz he's a batty boy amiright?
Anyways,
Going to look at this white GTR monday with Weazy (if he can make it). If that doesn't all go to plan Jenkies is going to be without a GTR.
At 6k a second he'd be using ANSI modulation - which is unsupported by most ISP's.
G.DMT is the standard modulation type for most, ADSL2 and 2+ have their own modulation extensions, such as Annex M and the like.
For what its worth, I'd turn the router off for 30 minutes and then turn it back on - sometimes that will cause the exchange to do a full retrain on the adsl synch when it comes back online...
And the router can generally be found by opening up a command prompt and typing ipconfig /all - whichever is your default gateway is usually the modem router (unless you have a windows or linux gateway)
-D
all this computer talk is nuking my brain...
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. :cool:
haha, probably. sounded a bit sus to me. f**kin ruined my night though.
Fashion Police are at it again.
What shoes did they refuse?
What's he gonna do if he gets bashed in the streets
He ain't a bouncer he's just the fasion police
good song haha
funkoars f/ hilltop hoods - What I Want
welp, found out why my internet sucks.
its cause adam sucks.
they apparently cap uploads aswell. balls.
think ill move back to internode.
shits gonna be frustrating for the next 12 days.
yeah , they count your uploads.
Adam are shit, they overload their rim's causing shit speeds and reliability.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
