balls. internet is running so f**king slowly. but ive got 8gb left til i hit my cap apparently.
cleared history, cleared cookies, reset router, still running slow as all shit. any ideas?
Sync speed & snr?
Grab a test file to see what sort of speeds you're downloading at, if your ISP doesn't have any grab one of internodes http://mirror.internode.on.net/pub/test/10meg.test
hmm - wilall told me they wernt interested in tuning the stag
Thats funny. I was told some weeks ago to bring mine in for a tune because they have their new 4WD dyno. ;)
i wasnt asking wilall for a tune, was asking their opinion on a problem...?
Sync speed & snr?
snr?
downloading test file at the mo.. 6kb/s. fail.
Modulation on router on the correct setting?
can i get that in computer stupid? (aka, english)
Edited by scandyflick
You can access that setting in the routers home page... usually found at 192.168.1.1
If your on adsl2+ usually the modem/router likes that setting better than mmode or gdmt. Might not be the issue either.
Incidentally I'm surprised moderators haven't stumbled across the threads in the ' General Automotive Discussion' section of the forum..... LOL!
yep, thats pretty bad.
You can find yor sync speed in the modems config pages too, normally under something like statistics/line settings
If you're syncd well above 6kbps then it's time to call your isp to see wtf is going on, could be backhaul issues or incorrectly shaped, if the sync speed matches the download speed then it's also time to call your isp and lodge a line fault.
Which ISP btw
adelaide blows. had a friends going away party tonight. got refused from 2 venues ive never been to before because my footwear 'wasnt up to standard'.
are you f**king kidding? how the f**k can a glorified pub have a goddamn dress code? sorta killed what was shaping up to be a decent evening.
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. ;)
Coz he's a batty boy amiright?
Anyways,
Going to look at this white GTR monday with Weazy (if he can make it). If that doesn't all go to plan Jenkies is going to be without a GTR.
At 6k a second he'd be using ANSI modulation - which is unsupported by most ISP's.
G.DMT is the standard modulation type for most, ADSL2 and 2+ have their own modulation extensions, such as Annex M and the like.
For what its worth, I'd turn the router off for 30 minutes and then turn it back on - sometimes that will cause the exchange to do a full retrain on the adsl synch when it comes back online...
And the router can generally be found by opening up a command prompt and typing ipconfig /all - whichever is your default gateway is usually the modem router (unless you have a windows or linux gateway)
-D
all this computer talk is nuking my brain...
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. :cool:
haha, probably. sounded a bit sus to me. f**kin ruined my night though.
Fashion Police are at it again.
What shoes did they refuse?
What's he gonna do if he gets bashed in the streets
He ain't a bouncer he's just the fasion police
good song haha
funkoars f/ hilltop hoods - What I Want
welp, found out why my internet sucks.
its cause adam sucks.
they apparently cap uploads aswell. balls.
think ill move back to internode.
shits gonna be frustrating for the next 12 days.
yeah , they count your uploads.
Adam are shit, they overload their rim's causing shit speeds and reliability.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
