andrew will like this, domar will probly flame for it but got passed this via a chain email lol:
nah i quite like that one
it was floating around during reagans presidency - one of those jokes that can be modified to suit anyones taste
aka
Q:What do you call 15 blokes sitting around watching the Rugby World Cup on a tv?
A: The wallabies (or whoever the wooden spooner that year is)
-D
need a massive favor..
anyone got a mig welder i can borrow for like 1 day??
I have a gasless mig welder you can borrow. You going to the dinner tonight?
hey guys just wanna say great forum u got here i just wanna put my name out there and hope to meet some of youse in the near future :D
Welcome to SAU. :merli: There's a dinner on tonight (see sig below) .. you can meet more of us there :(
hey ruby, nah im not. its just to weld abit of exhaust up.. prob only need it for like 5mins..
and got me 6x speed flow fittings and hose for only $170 :merli:
cheering
EDIT. might hit up the dinner actually..
Edited by rad32
theres a 1m x 1m pile of horse shit in the middle of grenfell street, and every single car is smushing it into the road, tracking it down grenfell toward king william. town smells like an unkempt farmhouse.
aka
-D
LOL at that wallabies one
from that ped garry?
:merli:
lol
how do i tell which is the inlet and outlet on a oil cooler sandwitch plate and relo kit?
dont wanna get the lines mixed up.
core itself doesnt make any difference.
but with the plate and relo block, they should have little arrows (or simply, "in" and "out") on the ports.
on mine its the outside port on the block adaptor linked to the outside port on the relo block, then the inside port of that feeds the oil cooler core, then the coil cooler feeds the inside port of the block on the engine.
ok on the left is my plate that sits against the block, on the right thr relocation plate.
now u can see the two holes on each which go through to the hoses..
which is in and out?
there are no labels on them at all..
cheering
I'll bring the gear along in case you're there :D
I was on lunch and all i could smell was shit people were looking around at each other like someone had farted it stank
if anyone is keen on a few photos on Sunday, meeting up around 1:00ish, pm me within the next hour for my number. wont be a cruise, just driving to locations for some snaps. i aint no pro either, just getting used to my new SLR.
haha shit
i gotta walk that way to the bus stop after
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
