Your ride height is far from low
if i had stiffer suspension it wouldnt bottom out.
these bilstiens, while being hard compared to std shocks, are spongy
writeoff can attest that when i was going to moonta last year, we'd hit a dip and my entire exhaust would bottom out on the tarmac and shoot a tonne of sparks, so much so that it ripped apart one of the welds on my muffler
its not about how low it is, its about how the ride height interacts with the suspension - i'd be fine if I had totally stiff suspension but thats not the case
-D
Need coilovers
would be nice, but i need something thats street legal - got any tips on something that
a) rides nice on the street
b) is legal (or can be engineered)
c) is firm enough to handle well
d) doesnt bottom out
I got bilsteins atm but theyre the basic version (and probably getting long in the tooth)
If it wasn't an issue of legality I'd just buy the ISC coilovers and be done with it
-D
*plugs antenna back in*
Safe to assume an 02 sensor shouldn't be doing that an its probably farked?
/noob
Thanks!
Well actually yes that's what a narrow band O2 sensor will do when the engine is in closed loop mode. If you look at the voltage output from a narrow band sensor there is a big difference in the voltage between 14.6 and 14.8 and all the ECU does is aim above till it gets a low voltage and then aims below until it get's a high voltage, so by constantly going above and below it averages 14.7 which what we are looking for.
-D
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :laugh:.
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :(.
hey Dave i hear your car is looking heaps good now
can you pm me some pics ? :3
lol. its looking fully reasonable.
havent had a chance to take any pics yet though (only got it done yesterday), but ill be out taking a few snaps tomorrow night. so stay tuned.
awesome, my mate saw you drivin the other day , i look forward to seeing images! :ermm:
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :ermm: .
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :) .
ahh brew ur twisting my arm eh brew
ok, are they off your car? I might see if my mechanic can fit it next week for me to test - I'll take it to and from loxton with your permission
-D
manage to find all my stock parts for my suspension. Hopefully i can get it cleared by the end of next week.
Main thing im worried about are the gauges, and fitting up a brake light to the rear window.
Yeah they're from my car man.
I don't see a problem with you taking them to and from Loxton, I'm sure someone has some details about you incase you do a runner - LMAO
*points to trader rating*
and sled knows where i live haha
-D
can I ask what steering wheel you had and what reason theyve given for it being illegal?
-D
I have a rear window brakelight out of a 32-R that you can borrow if need be. Ive been too lazy to put it in mine. Only need power and double sided foam to make it work.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
