Your ride height is far from low
if i had stiffer suspension it wouldnt bottom out.
these bilstiens, while being hard compared to std shocks, are spongy
writeoff can attest that when i was going to moonta last year, we'd hit a dip and my entire exhaust would bottom out on the tarmac and shoot a tonne of sparks, so much so that it ripped apart one of the welds on my muffler
its not about how low it is, its about how the ride height interacts with the suspension - i'd be fine if I had totally stiff suspension but thats not the case
-D
Need coilovers
would be nice, but i need something thats street legal - got any tips on something that
a) rides nice on the street
b) is legal (or can be engineered)
c) is firm enough to handle well
d) doesnt bottom out
I got bilsteins atm but theyre the basic version (and probably getting long in the tooth)
If it wasn't an issue of legality I'd just buy the ISC coilovers and be done with it
-D
*plugs antenna back in*
Safe to assume an 02 sensor shouldn't be doing that an its probably farked?
/noob
Thanks!
Well actually yes that's what a narrow band O2 sensor will do when the engine is in closed loop mode. If you look at the voltage output from a narrow band sensor there is a big difference in the voltage between 14.6 and 14.8 and all the ECU does is aim above till it gets a low voltage and then aims below until it get's a high voltage, so by constantly going above and below it averages 14.7 which what we are looking for.
-D
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :laugh:.
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :(.
hey Dave i hear your car is looking heaps good now
can you pm me some pics ? :3
lol. its looking fully reasonable.
havent had a chance to take any pics yet though (only got it done yesterday), but ill be out taking a few snaps tomorrow night. so stay tuned.
awesome, my mate saw you drivin the other day , i look forward to seeing images! :ermm:
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :ermm: .
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :) .
ahh brew ur twisting my arm eh brew
ok, are they off your car? I might see if my mechanic can fit it next week for me to test - I'll take it to and from loxton with your permission
-D
manage to find all my stock parts for my suspension. Hopefully i can get it cleared by the end of next week.
Main thing im worried about are the gauges, and fitting up a brake light to the rear window.
Yeah they're from my car man.
I don't see a problem with you taking them to and from Loxton, I'm sure someone has some details about you incase you do a runner - LMAO
*points to trader rating*
and sled knows where i live haha
-D
can I ask what steering wheel you had and what reason theyve given for it being illegal?
-D
I have a rear window brakelight out of a 32-R that you can borrow if need be. Ive been too lazy to put it in mine. Only need power and double sided foam to make it work.
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
