my bet is they saw the defect sticker and thought hey lets pull him over and let him know his cars defected.....when i had a defect on my car it was like a freaking homing beacon to them get pulled over everytime just for them to say did you know your cars defected? nah ohrly couldnt see the two bright yellow stickers right in front of me......
/rant
Was just a check to see how long I have to drive it. Was 3 chick cops to, but damm they were fine. Can stop me anyday.
On a amercian muscle car cruise and just had a car bouncing down the rd on hydros. U can smell the methonal mmmm
"i dont have a backseat, but if youre flexible, ive got some awesome monkey bars."
I was chased by a cop on foot down Hindley st once cos he saw a defect sticker on my skyline, i was only defected about 10 minutes before :ermm:
Watching Bathurst, just spotted blue mesh on car 34, had a bit of a chuckle!
Its becoming famous :)
Also ... someone keeps calling my mobile when I'm not near it and I'm missing the call (mostly when I'm driving). Number comes up as "unknown" so I can't call you back. If its anyone from here, can you SMS me your number and I'll return your call. Thanks.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
