my bet is they saw the defect sticker and thought hey lets pull him over and let him know his cars defected.....when i had a defect on my car it was like a freaking homing beacon to them get pulled over everytime just for them to say did you know your cars defected? nah ohrly couldnt see the two bright yellow stickers right in front of me......
/rant
Was just a check to see how long I have to drive it. Was 3 chick cops to, but damm they were fine. Can stop me anyday.
On a amercian muscle car cruise and just had a car bouncing down the rd on hydros. U can smell the methonal mmmm
"i dont have a backseat, but if youre flexible, ive got some awesome monkey bars."
I was chased by a cop on foot down Hindley st once cos he saw a defect sticker on my skyline, i was only defected about 10 minutes before :ermm:
Watching Bathurst, just spotted blue mesh on car 34, had a bit of a chuckle!
Its becoming famous :)
Also ... someone keeps calling my mobile when I'm not near it and I'm missing the call (mostly when I'm driving). Number comes up as "unknown" so I can't call you back. If its anyone from here, can you SMS me your number and I'll return your call. Thanks.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
