Bloody hell Luke. That was hella quick. I would still be sulking and my thumb wouldn't have left my mouth yet to even pick up a spanner (or a phone in my case).
Good luck. I hope you get through 1st time.
spent the last couple hours stuffing around with a very old school pentax mv1 (1980). its rather amusing. forgotten how heavy these motherf**kers are. got a random collection of fixed focal lenses, telephoto zoom lenses and such. think i might have to buy some more film and some batteries tomorrow. i like it. even being such a heavy mofo...
... i think i need a dark room.
Edited by scandyflick
I'm runnin twin HKS pods because thats what came with my car lol - so for that reason and that reason only I'll stick with them just chase down some new elements, anyone know where they're sold at a decent price?
on the plus side, standard airbox will keep the boys in blue happy, and you can still run a bit of power through them. im pretty sure Cubes was running around 300rwkw with a standard airbox?
damn posers :P remember if you get pods they need to be secured to something or its defect
i stick with the hks's also cause they come with the car. stock is better cause its enclosed and keeps the engine heat away, you can ofcourse build your own lil enclosure for the pods if you handy with that sort of thing.
Edited by Inline 6
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
