but then here is my list...........
Tomei Stroker kit RB25/26 2.8L $11,111.47
RB28 Titanium Top Ring Coating $593.89
Type A Tomei Camshafts (couldnt find the Procams which are the ones i want) $981.45
Tomei Head Gasket - Metal Super Gromment $463.31
HKS Fuel Rail Upgrade $427.00
HKS 550cc Injectors $1029.36
Tomei Adjustable Cam Pulley (Pair) $500.10
Tomei Valve Lifters $785.21
Tomei Shim Set $147.48
Tomei Valve Guide $750.31
Nismo Short Shift $248.44
Nismo Braided Clutch Hose $103.84
Nismo GT-LSD Pro $1665.34
Trust-Greddy Oil Cooler $883.04
Nismo Stainless Brake Lines $306.68
=$19,996.92
:bunny:
and i missed a few things too on that list lol
Edited by MissR34
lol doing that kind of rebuild can set me up for either turbo or supercharger (which im leaning more onto than a turbo)
ive always wanted to go the 2.8L stroker kit since i first saw it was available......its a bugger its sooo much tho lol
lol i didn't say yours will be a track car, but if you supercharge and stroke your engine, im gonna have to have 300+ at the rears to beat you, which is way too much power for a daily (for me anyway)
why not go super/turbo and have the best of both worlds?lol
hahaha that could be an idea
but i just love the sound of the supercharger........the whineing noise gives me goosebumps every time......and yes if i do go ahead with it........i will have a blower hangin out of my bonnet :bunny:
its just hard to find one to suit the RB engine, there is a company out there that makes them, not i cant seem to find out who is it.....Blitz make em for Toyota's (seriously, WTF).....so i may have to go universal and make up my own kit, which i know is possible.......
can u imagine a r34 with a blower!!! FARK that would be soo coool lol
Guest
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
