Cheers Pete, it does feel good! :D I have to thank you the most, they are your turbos after all! :rofl2: Just a shame I had some gremlins stopping me from running full boost, would have broken 320kw me thinks
Dave, yeah it does sound good mate, pity you didn't hear it on the rollers, hit up my facebook soon though and you can see the run!
anyone get defuct last nite at lofty?
a couple of my mates got done by unmarkers :)
yeh i got a msg from mitch last night.. was gonna take the rolla for a strap but thought twice!!
must be mass cop heat atm!
welcome to the 300 club buddy boy
yeh welcome to the 300 club Luke
awesome power curve on that dyno sheet u got there. welldone
also god to see you went to Morpowa, Simon is a GREAT bloke down there and very helpful
how does it feel on the road???
ACTUALLY... I ended up going to Shaun at boostworx ( long story, I know I changed my mind more times than I changed my undies :) ) but I'm very impressed with the power and it's delivery. Feels sweet as on the road, struggles a bit for traction though, putting the front shaft back on tomorrow when I get her on the hoist. Simon commented on the tune, in his words "perfect" Couldn't get any better praise than that. I think he wanted me to move to E85 though :P
what was the "knock" reading if u dont mind me asking
Well, the results are in if anyone cares... Had a boost controller issue, only able to wind 16psi into it but still good numbers!
Noice! Well done. Stuck with 16psi ... what were you aiming for? 20+?
I'd be happy with 200 out of the Stag when I'm done.
bought a new family car today, not a skyline/stag sadly, but decent none the less.
got a 2000 Holden Vectra olympic edition in metallic blue, 107k power everything etc.
they where asking 9999, managed to screw them on a 4 k trade in for the 99 auto 1.5ltr lancer..hehe
so $5999 cash on top of shitty lancer, im happy with that.
20 would be the MAX, more like 18psi. Either way I'm happy with the results
I am hopefully going to be getting 250rwkw or above out my R33 around September/October time.
Fantastic power mate, MORE than plenty really. After driving the R around in RWD mode, you realise just how much 300+kw is. 250 is a very respectable figure
Should've read "stuck on 16psi" not "stuck with 16psi" ... not like you had a choice by the sounds of it.
Obviously you ran it on AWD. I'll be squeezing my lemon later in the year to see what I can get out of it ... in AWD also (and a manual box conversion).
I recall Ben (Grim) passing comment to run 24psi in this stag eventually. Be interesting what he gets out of that "family wagon".
Edited by RubyRS4
Guest
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
