I can highly recommend jack for solder jockey work ;D (after all Im shit at it and made him do it all)
My dick is still bigger than his tho yall
-D
Bahahaha :laugh:
If any one wants to check out VDO's range of gagues...
http://www.egauges.com/vd2_main.asp
i might be getting Saber gauges depending on the price :laugh:
i recall have a chat to you about saber, i believe i may have included the following words and terms;
cheap
crap
avoid at all costs
also, lol at the post stats for the wasteland.
Damo_R34 2354
Madaz 1914
and a quick question, if i go ahead and say, buy a 2871R, id pretty have to get a retune eh...?
Edited by scandyflick
welcome :laugh:
if your interested in entrering shows and stuff im the SAU:SA Events Coordinator :D
thanks i'll keep it in mind but i think i should spend a bit of time and money on the car first before entering it in shows.
but thats the long term goal anyway, make it showy :D
I would, yes. Fit your EBC, get a retune, profit. If you could get some bigger injectors and a larger AFM while you're at it you'll make better use of the turbo but still, will be sweet regardless
Yep GT2871R will mean injectors 740cc, Z32 AFM, and a remap at the very least (at least the remap will only cost you around $600 including the daughter board) and to get the most out of that turbo you should really get cams. Without cam your looking at around 230rwkw and with cams your looking at 250rwkw. If you don't want that power then look at a GT28RS, that'll be around 220rwkw without cams and 235-240rwkw with cams. Standard SR's will take 250rwkw without a problem depending on how you drive it and how good the tune is.
EDIT!!
I'm pretty sure the use of any harness is illegal in SA.
Edited by D_Stirls
looks like ill just be getting the t28 rebuilt then, ive got other things i need to start getting the money together for. car has to be put on the back burner sooner or later.
cant justify the nigh on $2k.
i was told years ago (by regency) a harness is legal if you have the stock belt still bolted in and functioning.then i got pulled over and fined for not wearing a seatbelt,was using a 4point momo harness...and got the old Rx-7 defected at the same time for my troubles..
who knows really???
Guest
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
