Had some 40-something daddy wanting to drag me off at every set of lights with his 'TRD edition' Aurion this morning.
I think he was getting more and more irritate the more I ignored him :rolleyes:
i hear this, i think everytime an aurion has pulled up next to me they have wanted a race. i think the 200 kilowasps propaganda goes to their heads
Staying in tonight (no money, saving it all :rolleyes: ). Just came home from work, also bought new work shoes today which I'm stoked about. The other ones were falling apart.
Going out for a drive before Uni tomorrow, probably around the north to check out the Port River bridge and the Northern Expressway progress.
well tonight has turned out to be interesting.
i was watching the men's hockey bronze match (we won btw) and i heard 2 loud thumos.
next thing my sister comes in and tells me some1 ran into the paddock across the road
they took the fence out, hit a tree, and in his escape reversed into another fence then as he took off
almost ran over my dad and brother. didn't have his headlights on :rolleyes:, dad managed to get his number
plate so hopefully the cops catch up with him.
oh we also have the fire fighters out :), coz there was heaps (of what we thought was) acid
on the road, it smelt pretty bad, but yeah they said it was just water, luckily.
how much did you pick them up for? i think jis sells those dials as well!
anyway i was at a traffic light on torrens and woodville rd i think and there was a vy ute doing donuts in the middle of the intersection till the other lights went green :rolleyes:
Guest
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
