after watching the great race on the weekend i was thinking would our mighty gtrs still keep up?current model...
im sick of watching the holden/ford thing would be great to see some gtrs,evos,wrx in the race...
https://www.sau.com.au/forums/topic/188452-gtr-vs-the-v8-supercars/
  • Replies 160
2:08.4651 is the lap record set this year.... the GTR was in the 2.13s or something from memory.
A pretty good time considering the aero aids that are allowed today!
Edited by RNGTR
What I want to see is JGTC/Super GT cars versus V8 Supercars!
I think the DTM cars will chew em up and spit them out. They all have different restrictions etc, so you can't truly compare em. Would be awesome if someone would come up with a global touring car championship... I guess like the Mixed Martial Arts Championships for GT cars :)
DTM > JGTC > BTCC > V8 Supercars > Nascar (yeehaw)
Would be an awesome sight but, wouldn't be fair. The Super GTs would need to have some restrictions in place. Going by lap times on circuits like Sepang, Motegi & Phillip Island - Super GT > Moto GP > V8 Supercars.
Well after watchin an interview with some race director dude, who was with the euro tourin cars and aussie cars as well as the americans and F1.. he says the JGTC cars are the fastest GT style cars on the planet.. and i dont think his wrong :)
Aero aids on the V8s? Like I know they have wings and stuff...
Also, when did that extra chicane go in?
Given the type of race I would have thought the lemans series cars probably would have been best suited.
http://www.drive.com.au/Editorial/ArticleD...ArticleId=44148
There you go guys, its the race record and not the lap record that hasnt been broken yet
Still cool though...
yer i just checked the records.. they still hold the Race record of 6hrs and 19mins.. current crop from 2000 onwards r still a fair way.. even the VR was closer with 6hrs and 20mins.. hahah now theyre doin 6 hrs 29mins
god bless the monster the R32 truly is :)
Gun,
I personally think that given the right rules, it'd be dammed interesting...
If you looked the way that the Performace cars ran round the mount, and in many ways were quicker over the top, then a well setup GT-R with the power could be the package to win...
As others have said, it'll be the restrictions and rules that kick it in the bum...
ffs, the '32s IIRC, are still restricted on the intake for AUS circuit racing??
Gun,
yeh very intersting indeed.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
