Hey guys and girls
Im thinking after i finish my track gtr on building a 32 drift car with a 302 v8 we have sitting around.
What you guys think got the idea this morn on the way to work mostly from the 34 with the Holden in it.
Thinking of going supercharger in it.I like the idea of having shit loads of smoke coming out the back from all that torque
Edited by dmac_25
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/
keep in mind the weight that will be added to the front.
If you wanted to do it properly(lots of money) get an alloy racing block and alloy heads and that way the car will handle closer to stock.
however thats a lot of money.
Good luck with it, the 302 will fit in the engine bay and you will still have a high reving engine. I recomend a windsor.
Mine revs out to 6800 as a stocker. The clevo's arnt anywhere near as high reving and as a standard motor tend to be a little under powered at the 302 level, different at the 351ci + sizes
My 2 cents
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3406840
You have some good points there but i wouldnt think that it would be much heavier than than the gtr engine with the front diff etc also the engine would sit back further in the bay because of the length difference.
i could have debate on the windsor clevo issue tho im a clevo fan as i think the windsor 351 isnt worth the trouble but the 302 is a great motor thats what we have got its just sitting there on the shelf
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3406889
an iron block 5 Litre in a R32 might not be your best choice, if you not scared to change brand names for a transplant why not a 1UZFE...cheap as chips to buy and you get a much better V8 (6 bolt mains etc)
The fact that we have already got the engine and that im a ford and nissan man i thought just mix the 2. also my old man is an old school mechanic and he could get it cranking pretty good
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407039
Was going suggest an alloy V8 such as LS1 but you have your reasons. Could be a cool thing, but weight will always be there as you know.
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407075
Yeah i got good reason not to put one of them in and also its already been done before was thinking of keeping it old school with the cary then maybe upgrading to fuel injected later still will get 500hp out of the old girl.
The fact that the weight is going to be back further will help i will weigh it to see what extra kgs it puts on with the right front end setup should be ok
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407125
Fair enough....it sounds like an interesting project and seeing you already have the 302 why not hey. It would be interesing to see how much heavier a 302 really is compared to an RB...and your spot on there is nothin wrong with a
5 Liter Ford...we get 625hp out of ours...not bad for 7500 rpm limited on pump premium
Edited by gtr660hp
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407224
My thought exactly just for something different i could also put in 351 clevo we also have there im not sure which box to put behind it the late model 5 speed of the top loader?
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407242
dude dodge the Clevo they are much heavier at 550lb (250kg)
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407338
The windsor is not that heavy i was thinking the top loader wouldnt need all those gears for drifting.
Why not the clevo that ones got some serious grunt the old man did a good build with that one ported and matched full rebuild it reved its tits off lol
You recon twin puffers or the blower?
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407383
Hasn't someone done this already in a 34GTT? I think they had a lot of balancing issues with the front being too heavy aswell. I'm pretty sure it's a drift car, or they use it for drifting aswell. Red in colour if my memory serves me correct.
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407957
Yes but it had an LS1 in it, not a Windsor.
If you want to run a Windsor you need to spend up on some nice alloy heads, probably a stroker kit & pay close attention to manifolding & exhausts. Even then I don't think it will hold a candle to an RB26.
None the less good luck.
Oh & top loaders are well old school. Try Tremec, rubbish shift feel aside.
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3407999
Your right bout the 26 i will prob keep it as a drift pig as the engine is now then build it up once the problems have been sorted with it
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3408024
GT Autosounds built the LS1 twin turb R34
engine is as heavy as the rb and weight distribution was better as it is a shorter length engine
i say go the 302 and a tremec box - top loader is bit too old school
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3408077
You guys realise he already has the engine, so there's no point trying to push your opinions on different engines.
you wanna do this as a fun project, and somethig different go for it! But keep the carby i recon... :domokun:
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3410388
It's not like it's a hard engine to get a hold of, neither is it rare or regarded as a powerful engine. Besides that a v8 in a skyline... it's been done many times before, not really original and will end costing you more than putting an rb25 in it, due to all the custom fabrication required.
https://www.sau.com.au/forums/topic/188984-302-v8-in-32/#findComment-3410659
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
