Hi Peoples,
Unfortunately just recently i hit a pole(stupid mistake in the rain)and destroyed the front end of my R33 1997 GTST, Engine fine, Front cut would fix but looking at pro's con's to sell or keep. includes
Gizzmo EBC 50lb rating
Turbosmart BOV
RB25 turbo 69990km service history exc cond.
Trans and LSD exc cond.
Japanese exhaust CAT back
Volk Rims 1 damaged
Panasonic stereo(fold out front speaker)
Viper Alarm
Rear M-Spec Bodykit
Interior exc cond.
Nismo Adjus. susp.
Just curious what could be made from selling as is or better to break down or to fix? if i decide to sell i would rather do in one hit. Attachments show damage
Any help appreciated
Cheers
https://www.sau.com.au/forums/topic/189261-skyline-r33-damaged/
  • Replies 50
Posted Images
That's gotta suck. Oh well I guess next time you will probably think twice before pushing in the rain.....
It all depends what you really want. It will cost a bit to fix if your not insured. depends if you really like that car and want to hang on to it or if it is time to move onto something else. ultimately the decision is yours.
you'd make more by stripping it down for parts than selling as whole, but this can be time consuming to do, if you repair it will obviously need a cut/shut on atleast the right rail/skirt and rad support, though the left also looks damaged, if the chassis behind the firewall is also damaged I wouldn't even bother with fixing
on another note if you sell parts I'd be interested in front/rear brakes
Hi People
Just an update!
I am looking today to get prices of either to wreck or repair, heading towards a wreck, noticed a few people interested in certain things, this process may be time consuming but ill do my best. everything i decide to sell will be in condidtion it was before the crash, i wont sell fudged parts. ill be back on SAU tonight hopefully with more concrete info.
Thankyou for your thoughts so far, greatly appreciated so far
My Baby!! :down:
hello again people
well today a wreckers gave me a rough quote without looking at the car roughly $4000 the lot, i am waiting on another quote but heading towards being happy with taking anything around the $4000 to $5000 mark hopefully. paid all up around the $26000 in total so its kinda hurting alot. but if anyone came up with those figures well? for those interested in parts the final decision will be made tomorrow as the other wreckers may not be able to come out till tomorrow.
Thanks for your patience
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
