  • Replies 64
Just adding my 0.02c
Front - definitely go with SAU logo and afterburners with TeamTrackday underneath.
Back - maybe the 4 NSW circuits ( for now ) in a 2 x 2 format. Could label each circuit with location details and track length. Individuals can add their best times for each track inside the track outline with a permanent marker.... may get messy if you keep getting faster though.
Z.
Zane, to combat the messiness problem, perhaps put the tracks two-by-two, but leave a fairly large gap between the top two and the bottom two, that way as you say, using a permanent laundry marker you could stack times up, when you break your best time, add the new time underneath your previous best, with the date. Cool little memento for when you're old and grey. :rolleyes:
OR another idea that may suck,
Subtle club logo on the front,
On the back Nismo logo up top across back of shoulders,
Then the outline of Mount Panorama,
Alongside the track '91 '92 '93 in a vertical line,
Then at the bottom something like SATCC Winner 87,90,91,92,93 (are those years right im going off memory)
OR my preference replace Bathurst with outline of the Nurburgring, and for years replace with the years that the R32 and R33 help the production car records. Then on the bottom a stamp like logo saying "Nissan Skyline - Approved for Racing Purposes"
Merli just made me think of something.
How about a "Yellow jersey" arrangement.
For when the club starts more regular events. Say we nominate a lap time, and the person who gets within the closest window of lap times gets a yellow (or other colour) shirt.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
