IMO your best bet is taking the car to a reputable tuner to get a compression and leak down test done... It should only cost $250 or so for a FULL inspection (including these tests), and it will tell you the condition of the most important part of the car - the engine! NRMA and mobile guys (that I know of!) wont do a compression test etc..
If the seller doesnt agree to take the car to a workshop to get it checked out, then he's probably got something to hide!
If you're a hard bargainer, you might be able to get him to take the cost of the test off the price of the car too :)
As NRMA I believe has stopped there mobile pre purchase vehicle inspection service. I was wondering if you guys can recommend any other reputable companies in sydney that do this?
Hey mate,
try and get someone who knows the cars rather than a standard inspection company.
When I was buying my first R33 (almost 9 years ago now), I had a so called NRMA expert spend a whole day going over a 33 I was interetsed in.
At the end of the inspection I got a report which graded the car in A1 condition apart from a few paint blemishes on the body. That same day after laying down a deposit I get a call from the seller, saying the car is running on 5 cylinders and that they would need 2 months to fix this and other issues (under warranty). They were quite cool and gave me back my deposit, but moral of the story is I would never trust a so called expert.
There are a fair few expert Skyline workshops who I would go too instead.
Just my 2c
Hey mate,
Just my 2c
Hence - why you need a compression test! :)
if its a basic car, like a run a round daily eg a vt commodore v6
id use VIP inspections otherwise, take it to a workshop that deals with those special cars
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
