i bought a hybrid kit with the 600x300x76 for my r33 and it works great. it is a tiny bit laggier than the stock cooler (with stock turbo) but it cools the inlet air alot better.
i have had a problem with the kit though, the top pipe returning the cooled air to the factory inlet piping runs infront of the radiator and gets very hot. this was wasting the good work that the cooler was doing and as a solution to this i bought some thermo-tec exhaust wrapand wrapped the intercooler piping in the engine bay and the piping from the turbo to where it goes into the front gaurd and i have found this to make the car seem more powerful (seat of my pants meter used) the car feels more consistantly powerful as before it was a little ordinary. i believe getting the heat away from this has given me a definite power boost. the pipe temp is noticeably different as now you can put your hand on the piping and leave it there after you have been driving whereas before you couldn't.
i intend to wrap the dump pipe until it is under the car too with the remaining wrap i still have.
se this link for pics of the cooler install... http://www.skylinesaustralia.com/photopost...500&ppuser=5132
back to the subject the cooler itself works great!
  • Replies 46
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
