SOLD SOLD SOLD
Make: nissan
Model: r33 gtst skyline
Colour: maroon
Price: $12,000 price drop $10000
Contact: MITCH 0410627751
Comments / Modifications: engine was done by boosted extremes had about $13000 spent on engine photos on http://www.boostedxtremes.com.au/. fully rebuilt engine with forged internals, port and polished head with race valves and springs, cams, custom plenum, custom exhaust manifold, gt35r turbo, fuel pressure regulator, custom intercooler piping and fmic, bov, 2 stage boost controler, remapped computer. front bar has been repaired and is in primer.car comes with DRR33 plates
Images: post-42725-1193043527_thumb.jpg post-42725-1193043968_thumb.jpgpost-42725-1193043983_thumb.jpg
Edited by DRR33
https://www.sau.com.au/forums/topic/190279-fs-qld-1993-gtst-r33-10000/
  • Replies 60
Posted Images
hey mate not sure how much power its making but ive been told that its will make 400hp+ atw, going to strip this weekend for qtr mile time, got 5 spoke 17s, body is good but needs paint has been painted by previous owner but needs to be redone, no sunroof, there is more stuff on the car than i said but cant think of it.
Edited by DRR33
car currently running on 10psi will make 300kw atw on this settin but with a good dyno tune and more boost can make a lot more.
your car is making 300rwkw on 10psi with a gt35 turbo?
and can make more with better tune and more boost?
or am I reading that wrong?
a little from column A and little from column B.
I know what I'm talking about and being a smart arse.
if you think that your RB25 makes 300rwkw using standard capacity and a GT35 on 10psi, you're either a YANK or you're confuisng KW with HP.
Maybe you should have your "seat of the pants" dyno re-calibrated.
had car dynoed at rotary motorsports last week
6psi-258hp
18psi-320hp
leaned out at 5500rpm needs fuel system upgraded
:worship::P
Wow...
so it made 258HP (192.5kw) on 6psi
and 320HP (238.8kw) on 18psi.
But it makes 402HP (300kw) on 10psi like you said before?
Must need a tune..
Or does the turbo start turning backwards after 10 psi?
Maybe you can go back and edit your BULLSHIT posts.
then have a moderator delete this post for bagging out your bullshit lies.
is that all, u got that from a gt35r my mate nearly gets that from his hiflow but still a nice car, so wats missing to make this a 300rwkw monsta
thanks mate
well i found out that it still running standard fuel system, no cam gears, no aftermarket ecu, also running rb20 airflow meter, no aftermarket coil packs and its runnin a stock auto.
car has never been dyno tuned so this car has so much potential.
ben at rotary motorsports said with all this done and a few hours on the dyno it will pull 300kw easy.
Edited by DRR33
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
    • Looks fancy But after having a look, prior to its installation, I noticed that the yellow looking power steering reservoir would look crap next to this So I have this incoming..... Much cheaper than the Moroso and has great reviews (yeap, it's a Moroso knock off)
    • Can we place bets? My money is on there is always the option to use the 1 way profile. So the diff is either 2 way and 1 way, or 1.5 way or 1 way.
    • I also used Knox driveshafts when I the slip yoke T56 to the 3bolted TR6060 type. I believe I was one of his first jobs as it literally changed hands when I was there, started by the old owner and finished by the new. Everyone seemed pretty great about it. So wasn't shy/seemed pretty knowledgeable when dealing with weird custom people like me.
